Hi all, Recentely mpserver15 is facing some hardware/driver problem which leads the server offline, and the only way to bring the server back is to restart it. I have tried to use some older kernels but the issue still presists. Mpserver15 runs in Ubuntu 10.04 LTS and I really hope anybody can direct me to the solution. Below is the log related to the issue:
And network card detail is as follows:
Any help is appreciated. To contact me, please email to hatsuki_a-ie 屌at屌 yahoo.com.hk Due to low usage and high operation cost on maintaining mpserver15, this site (mpserver15.flightgear.org) will cease act as mpserver with effect from 01.04.2014. Other service (i.e. FGTracker) will remain unchange. Power consumption of FGTracker server contributes a significant cost to me and now I proposing an additional downtime of FGTracker in flavour of my cost cutting plan. The proposed downtime is from 01:45 UTC+8 to 07:00 UTC+8 daily (That is, 17:45-11:00 UTC). Please drop me emails to hatsuki_a-flightgear atyahoo.com.hk for comments. Some time between 28 Jun and 30 Jun 2013 FGTracker not tracking mpserver01. I am a bit suprise that quite number of people in the community visits this site (XD) and very kind reporting me their findings. Let me explain the problem:
Because of buggy fgms (fgms is a program running in mpserverXX.flightgear.org),communication between fgms and FGTracker was failed and thus corruputed data has been feed in to FGTracker. Currently all servers which was running latest version had been roll back to latest stable version.
Algorithmn on calculating Ground speed has been changed in order to exclude the abnormal record (e.g. flight reset). In old times, when one reset the flghts, the "movement" will be recorded in the tracker and the speed and distance of the flight will become huge if the reset position is far away from the location of the plane before reset. Now, although the movement still records, the ground speed algorithmn will try to exclude the moment when the flight resets. If ground speed is over 2000 m/s, the ground speed will be assummed to be zero. By this setting, max mach, max ground speed and distance will also exclude the moment of reset.
In addition, "Effective flight time" is also introduced. "Effective flight time" tries to exclude the player idle time (i.e. ground speed <5 knots). In later updates, the "Effective flight time" will be used in top XX pilots list to prevent one idle the plane for gaining the rank. |
